| Area: | MicroStation CONNECT Edition Basics | ||
| Subarea: | Viewing Designs | ||
Regardless of the size of your screen, the view windows help you make the most of your system. You can configure view windows for maximum efficiency, taking into account your system, your project, and your working style. This section contains the wikis related to the Viewing Designs that includes Arranging View Windows, Using View Controls, View Control Bar, View Toolbox, View Control Toolbox, View Rotation Toolbox, Navigate View, View Perspective Toolbox, Set Display Depth, Set Active Depth, Show Display Depth, Show Active Depth, Change View Rotation, View Rotation Dialog, View Display Mode, Adjust View Brightness etc.
