| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Rebar modeling |
| Subarea: | Pad footing reinforcement |
| Original Author | Sandip Kar, Product Advantage Group |
Not able to place side bars in the middle. Want two side bars in the middle, but it always place at Top & Bottom.
To place the side bars at the mid of the concrete, one can use offset in Side Bars in Pad Footing reinforcing tool.
Using Offset value one can easily move the bars if he/she really don't want to have the bars at Top & Bottom.
