Configuration Audit Alert
Product(s):ProStructures, ProSteel, ProConcrete
Version(s):CONNECT Edition (10.06.00.60)
Environment:N/A
Area:Project
Subarea:WorkSet, WorkSpace
Original Author:Alistair Lobo, Bentley Product Advantage Group
An alert message pops up when opening a file in ProStructures Update-6
In the Update-6 of ProStructures CONNECT Edition, a new configuration has been added for a custom created WorkSet
As a result, when you open a file that is associated with this custom created WorkSet OR open a new file in a custom WorkSet, the ‘Configuration Audit Alert’ message pops-up and prompts to make the required changes in the WorkSet configuration file (*.cfg)
1) Open the *.cfg file for the WorkSet in which you are working, to edit
NOTE : The default location to find this would be - ‘C:\ProgramData\Bentley\ProStructures CONNECT Edition\Configuration\WorkSpaces\**Your WorkSpace**\WorkSets’
2) Add the below mentioned line at the end of the contents in this text file -
%include $(_USTN_WORKSETSTANDARDS)ProStructures/*.cfg
3) Save this text file and restart ProStructures
