| Version(s): | V8i | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Johannes Michalowsky, Bentley Product Advantage Group | ||
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
General | |
Why are nested elements not shown by the item browser? |
Presently, nested elements are not yet supported by the item browser. |
Why can I not merge a reference model to a master model? |
The merge command is presently not supported. However, the reference model can be copied to the master model. |
I cannot find the cloning command irregular dispatch rebar. |
Use MicroStation copy command and copy the rebar along with the construction line(s). |
I am unable to cope welded I shapes. |
Presently, coping of welded shapes are not supported yet. However, you can achieve the same result using polycuts. |
IFC | |
Which elements are not supported by the IFC export? |
Presently, MicroStation cells, concrete stairs, EED data, and some rebar properties are not supported. |
COE | |
The weight properties in the item browser is zero or incorrect. |
Copy ProStructureMaterial.mdb locally and edit ProStructures.cfg file to point the stored location of mdb file. |
When I reference a model, I am not seeing any elements or the elements are scaled incorrectly. |
Currently, the master and reference UOR must match. |
DWG Adapter | |
After editing my converted blocks/cells, they disappear in the dgn model. |
a) Any custom user blocks should be converted and copied manually to the appropriate path, and b) the block path name should be updated to point the new target location. |
ISM Connection Edition | |
My assigned material name is not recognized after exporting or updating my ISM file. |
The material name mapping can be made permanent by saving the material name to an exchange mapping file. |
