ProjectWise Compatibility matrix with ProStructures applications:
Please follow the below table for the compatibility matrix of different released versions of the ProStructures product with ProjectWise versions.
ProStructures V8i SELECTseries:
| ProjectWise release version number | ||||||||||||||
| ProStructures | 08.11.11.590 | 10.00.00.20 | 10.00.01.25 | 10.00.01.67 | 10.00.01.71 | 10.00.02.96 | 10.00.02.203 | 10.00.02.265 | 10.00.02.320 | 10.00.03.49 | 10.00.03.140 | 10.00.03.167 | 10.00.03.262 | 10.00.03.271 |
| V8i SS6 | ||||||||||||||
| V8i SS7 | x | |||||||||||||
| V8i SS7 Refresh | x | x | ||||||||||||
| V8i SS8 | x | x | x | x | x | |||||||||
| V8i SS8 Update 1 | x | x | x | x | x | x | ||||||||
| V8i SS8 Update 2 | x | x | x | x | x | x | x | x | x | x | ||||
ProStructures CONNECT Edition:
| ProStructures | 10.00.03.49 | 10.00.03.140 | 10.00.03.167 | 10.00.03.262 | 10.00.03.271 | 10.00.03.280 | 10.00.03.299 | 10.00.03.329 | 10.00.03.334 | 10.00.03.434 | 10.00.03.453 | 10.04.00.100 |
| CE (10.00.00.74) | x | |||||||||||
| CE Update 1 (10.01.00.23) | x | x | ||||||||||
| CE Update 2(10.02.00.20) | x | x | x | x | ||||||||
| CE Update 3 (10.03.00.58) | x | x | x | x | ||||||||
| CE Update 4 (10.04.00.47) | x | x | x | x | x | |||||||
| CE Update 5 (10.05.00.54) | x | x | x | x | x | |||||||
| CE Update 5.1 (10.05.01.11) | x | x | x | x | x | x | ||||||
| CE Update 5.2 (10.05.02.51) | x | x | x | |||||||||
| CE Update 6 (10.06.00.60) | x | x | x | x | ||||||||
| CE Update 6.1 (10.05.00.54) | x | x | x | x | ||||||||
| CE Update 7 (10.07.00.79) | x | x | x | x | x | |||||||
From the below link you can download above compatibility matrix for ProStructures Product with ProjectWise versions in excel file format.
communities.bentley.com/.../274617
ProjectWise Version Support Matrix - In this link, you can find the compatibility matrix between different products with ProjectWise version.
ProjectWise Compatibility Tool - Microsoft PowerBI compatibility matrix between ProjectWise and applications from Bentley, Autodesk, Adobe, Microsoft, etc..
Level of Integration - Also refer this Wiki Link to understand the Levels of integration.
