| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Detailing | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Position flags display four decimal points for the length of objects. Where to change the number of decimal points?
Current dimension style is set to four decimal points.
Menu Elements/dimension styles
The current style has a different background color
Modify the style Units/Precision
