| Product(s): | ProSteel | ||
| Version(s): | N/A | ||
| Area: | Detailing | ||
| Subarea: | |||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
Within the Detail Styles you can set he Position Flag Template to use.
You may want to set a different position flags with settings depending on how you may want it to appear on your 2D Files.
Note: You must have a pre defined Position Flag style before doing this.
See video below for your reference
