Product(s): | Promis.e, Bentley Substation | ||
Version(s): | through 10.00.00.232 | ||
Environment: | N\A | ||
Area: | Print_Publish Features | ||
Subarea: | Project Publisher |
How can I specify a pen table for Project Publisher to use so I can remap colors, hide elements with certain criteria, etc. on the resulting PDF file?
[[Project Publisher - create PDF files of your projects|Project Publisher]] uses the platform's Print process to create PDFs of the project pages. Setting the configuration to use a pen table for the print process will also affect Project Publisher.
Note that this method will affect all printing, not just Project Publisher output.
Set the MS_PLOTDLG_DEF_PENTABLE configuration variable to the path and filename of the pen table to be used. For example:
MS_PLOTDLG_DEF_PENTABLE = X:/Promise/MyPenTable.tbl
This can be manually added to a .ucf or .cfg file, or added to the user configuration with the following process:
[[Printing With Pen Tables]] to find out how to create a pen table.
Original Author: | Matt_P |
