| Version(s): | 08.11.05 through 10.00.00.232 | ||
| Area: | Print_Publish Features | ||
| Subarea: | Project Publisher |
How can I export my project into PDF format?
The Project Publisher tool is used to create PDF output of project drawings. Such output can be sent to end users that do not have Promis.e or Bentley Substation design software with which to review the project.
With Project Publisher:
* is used to denote a menu selection that is not necessary for some versions or platforms.
Click Help on the Project Publisher dialog.
For Bentley Substation CONNECT Edition, see the Project Publisher section of online Help for Bentley Substation available from Bentley Product Documentation.
The "Send To Printer" and "Drawing Files" features of Project Publisher were deprecated in V8i SELECTseries 8 (08.11.13) in favor of Print Organizer / [[Plot Page(s)]] and Batch Converter respectively.
[[Print to PDF]]
[[Pen Table use with Project Publisher]]
| Original Author: | Matt_P |
