Product(s): | Promis.e, Bentley Substation | ||
Version(s): | through 08.11.13.140 | ||
Environment: | N\A | ||
Area: | Database Platform Support | ||
Subarea: | N\A |
When trying to create a project database, the following error message is displayed on the Project Database Utility dialog:
Execution error: The system cannot find the file specified
The Project Database Utility uses tools included with the SQL Server installation to create the database. It relies on the PATH environment variable to find the necessary tools on the system running the Project Database Utility. The error message is displayed when the software cannot find such a tool. This can be caused by SQL Server not being installed on the machine running Project Database Utility, or a path is missing or incorrect in the PATH environment variable.
If SQL Server is not installed, [[Installing SQL Server|install SQL Server]] on the workstation even if attempting to create the database on another machine running SQL Server. SQL Server Express is adequate and bundled with Promis.e and Bentley Substation. To avoid trouble, it may be best to install the same version (2008, 2012, 2014, etc.) of SQL Server. Installing SQL Server should install the necessary tools and add the necessary paths to the PATH environment variable.
If SQL Server is already installed on the machine running the Project Database Utility, ensure the necessary paths are included in the PATH environment variable. Check this with the following process:
For SQL Server 2008 R2, the PATH environment variable should include the following paths or similar:
c:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files (x86)\Microsoft SQL Server\100\DTS\Binn\;c:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;
For SQL 2014:
C:\Program Files (x86)\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\ManagementStudio\;
The critical path may be the one containing SQLCMD.EXE (highlighted above).
Important: Restart the computer after making the changes to the environment variables.
The database can be created by running a script using SQL Server Management Studio. See [[Creating and Updating the Project Database]] for details.
[[Installing SQL Server]]
[[Install SQL Server Management Studio]]
Original Author: | Matt_P |
