| Product(s): | ProStructures, ProSteel |
| Environment: | N/A |
| Area: | Workflow |
| Subarea: | PS_compact |
| Original Author: | Steffen Knoll, Bentley Product Advantage Group |
1. AccuDraw is a very useful functionality, but secondary when using ProSteel.
2. in contrast, the quickest access for daily used commands is first priority.
- Display of all commands in one ribbon group without having to switch over
- Quick call of the function groups via keyboard shortcuts
- Afterwards direct command call of all important commands via keyboard shortcuts
The concept is based on the right hand at the mouse and the left hand at the keyboard.
Keyboard shortcuts are therefore all keys that are easily accessible for the left hand or key combinations of
two, maximum three keys.
Primarily these are the letters A, S, D and F on which the fingers of the right hand lie.
And secondarily all letters directly above, below and to the right, but not numbers or F keys.
