Error at startup - The type initializer for ECT.ECAD.UI.ShapeManager threw an exception
 Product(s):Promis.e, Bentley Substation
 Version(s):08.11.07.82
 Environment:N/A
 Area:Installation_Configuration
 Subarea:N/A
Error or Warning Message
The following error occurs at startup and project pages cannot be opened.
Microsoft .NET Framework
Unhandled exception has occurred in a component in your application...
The type initializer for 'ECT.ECAD.UI.ShapeManager' threw an exception.
The Details of the error include the following text:
************** Exception Text **************
System.TypeInitializationException: The type initializer for
'ECT.ECAD.UI.ShapeManager' threw an exception. ---> System.Xml.XmlException: Root element is missing.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res)
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()...
In other cases, the error message was:
The type initializer for 'ECT.ECAD.UI.ColumnManager' threw an exception.
How to Resolve
  1. Close the software.
  2. Rename or delete the user application data folder for the software:
    [[Application Data (per-user configuration) - Promis.e]]
    [[Application Data (per-user configuration) - Substation]]
 Original Author:Matt_P
Keywords: cannot open page, project, ShapeManager, ColumnManager, shape, column, manager
P/S: 39533,500000066132
