| Version(s): | through 10.01.00.23 | ||
| Area: | Component Management | ||
| Subarea: | Catalog Manager |
Catalog Manager is used to categorize, rename, delete, and copy symbols, macros, device families, and title blocks. It can also export and import catalogs as a means of backup or for transferring to another user.
Using the Thumbnail view, Catalog Manager is a good tool for finding a symbol or macro when it can be recognized visually but the name is not known.
* is used to denote a menu selection that is not necessary in some versions or platforms.
[[Add Catalog Path]]
[[Create a new catalog]]
[[Export Catalog]]
[[Import Catalog]]
[[Rename a catalog]]
| Original Author: | Matt_P |
