| Product(s): | ProSteel | ||
| Version(s): | ProStructures CONNECT Edition (10.XX.00.XX) | ||
| Area: | Connection | ||
| Subarea: | N/A | ||
In this document, we are going to learn how in ProSteel CONNECT Edition, General Baseplate can be placed to a column with the Anchor bolts.
1. First place a column and then connect a General Baseplate which is located under Home tab at column base. (Refer the snaps below).
2. After placing the Baseplate, the General Baseplate dialogue box will appear. In this dialogue box go the connect tab and under the Bolts section, switch on the option ‘ Connect with Anchor Bolts’.
You will see the Baseplate connected to columns with Anchor bolts.
3. Here you can also change label of bolts and other settings as well.
In this way we can connect the base-plates to the required elements with the Anchor bolts.
