| | Product(s): | Promis.e, Bentley Substation | |
| | Version(s): | through 10.01.00.23 | |
| | Environment: | N\A | |
| | Area: | Reports_Output Features | |
| | Subarea: | Wiring Diagram | |
I set the Show terminal jumper line check box in [[Options]] > Project Options > Wire Diagram Settings > Cable Diagrams, but jumpers are not appearing on the wiring diagrams for the terminal blocks.
Steps to Resolve
- Ensure that the wiring diagram symbol used for the terminal blocks includes a connection point for the jumper. Place the jumper connection point where the connection node should appear to indicate the terminal is jumpered. The Hidden Text value for the jumper connection point on the wiring diagram symbol must match the Visible Text value for the jumper connection point on the schematic symbol. This value is typically J but may be different.
- After modifying symbols, be sure to update their definition in the project by using [[Update Symbol]].
- Use [[Update Wiring Diagram]] to update the page containing the wiring diagram(s) in question.
Jumpers should appear on wiring diagram symbols as red lines and dots (connection nodes):
The related schematic that drives the above cable diagram:
