| Product(s): | Promis.e, Bentley Substation | |
| Version(s): | through 10.01.00.23 | |
| Environment: | N/A | |
| Area: | Component Management | |
| Subarea: | Terminal_Pin_Plug Manager | |
Terminal/Pin-Plug Manager can be used to:
- Rename terminal strips and plugs
- Change the order of terminal blocks and plug pins
- Renumber terminals and pins
- Insert accessories
- Assign part numbers to multiple terminal blocks
To open the Terminal/Pin-Plug Manager tool
* is used to denote a menu selection that is not necessary in some versions or platforms.
CONNECT Edition
- Right-click a schematic terminal block symbol and select Terminal/Pin-Plug Manager from the resulting context menu
- Select the Manage ribbon tab > Project Data group > Terminal/Pin-Plug Manager
V8i
- From the Tasks or ribbon area, select Review/Revise > *Revision Management > Terminal/Pin-Plug Manager
promis.e 2007
- Select Manage > Terminal/Pin-Plug Manager
For more information
Click the Help button on the Terminal/Pin-Plug Manager dialog.
Alternatively, for Bentley Substation CONNECT Edition, see the Terminal/Pin-Plug Manager section of online Help for Bentley Substation available from Bentley Product Documentation.
