| Product(s): | ProSteel | ||
| Area: | Steel Connections | ||
| Subarea: | N/A | ||
While using the connections, many users have to include the user defined data in the connections. For addition of connection database entries there a specific procedure which needs to be followed to add the database entries. In this wiki, we will learn how to add the connection database entries for the purlin connection.
From the link given below you can download the document which explains the stepwise procedure for adding connection database entries for the purlin connection.
https://communities.bentley.com/products/prostructures/m/drafting_and_detailing_gallery/274812
