| Product(s): | Bentley Substation CONNECT Edition | |
| Version(s): | 10.00 - 10.02 | |
| Environment: | N/A | |
| Area: | Installation_Configuration | |
| Subarea: | N/A |
In the CONNECT Edition, the application makes use of WorkSets to apply configuration settings to projects. Therefore, it can be advantageous to take advantage of template WorkSets to drive the creation of a new WorkSet. By doing so you can apply project specific settings to any new project that you create. Here are some typical uses for a template WorkSet:
A template WorkSet is no different than any other WorkSet except for how you intend to use it. In other words, any WorkSet can be treated as a template to create a new WorkSet from.
You have two options for defining template Worksets:
You can make use of the existing template WorkSets to preload your own custom content as needed. By default, Substation delivers two template WorkSets that can be used to create a new WorkSet which predefines various configuration variables. The template WorkSets that are delivered by default are:
You can rename these templates, if desired, by renaming the WorkSet folder and the corresponding WorkSet.cfg file. By default, these WorkSets are found in the “Substation Example” workspace here:
C:\ProgramData\Bentley\Bentley Substation CONNECT Edition\Configuration\WorkSpaces\Substation Example\Worksets
To modify configuration settings for a template WorkSet you can directly edit the configuration file. The configuration file for the template WorkSet has the same name as the template workset itself and is located in the root of the “Worksets” folder listed above.
You can specify any configuration variable you desire and set its value in this configuration file to achieve your desired goal. Please refer to this article for a complete listing of the application specific Configuration Variables. The following example would load a project specific catalog when creating a new project using this workset as a template:
ELEC_CATALOG_PATH = $(_USTN_WORKSPACESTANDARDS)$(_USTN_APPLICATION)/Catalogs/MyProjectCatalog/
You can select the Create WorkSet button in the Project Manager to create a new WorkSet and assign it the name of the template you would like to create. Once the WorkSet is created, you can edit the configuration file that matches the name you assigned to the WorkSet.
Note: Any files you include within the template WorkSet folder will be copied to your newly created WorkSet.
