| Product(s): | ProSteel | ||
| Area: | Detail Center Standard | ||
| Subarea: | Parts tab | ||
This section contains the wikis related to the Parts tab of Detail Center Standard tool in ProSteel CONNECT Edition.
The Parts tab is used to:
- view a list of parts and views for your model
- select, create, or modify detail styles
- assign views or parts to the desired detail styles
