| Product(s): | ProSteel | ||
| Area: | Detail Center Standard | ||
| Subarea: | Settings tab | ||
This section contains the wikis related to the Settings tab of Detail Center Standard tool in ProSteel CONNECT Edition. This Settings tab is used to set up options and preferences for the Detail Center.
In addition to the settings of the different work levels, you can use this tab to make the fundamental settings of the Detail Center. However, you will also find special default settings, which are valid for several work levels at the same time and which are set centrally.
