| Defect Number | Description |
| 1002977 | When exporting a DGN file to DWG some of the symbol graphics were placed on the wrong layers and thus their visibility was turned off |
| 1004929 | The Backup / Restore command found in the File>Tools menu did not launch the proper dialogs |
| 1000354 |
Corrected a typo in a warning message that would occur if you did not specify a configuration value in the Configuration Variables dialog.
| 1006499 | When executing a Fit View and the selecting File>Close you could get a message that Promis.e CONNECT Edition has stopped working. |
| 998057 | If configuring the software to use a network WorkSpace the following alert was displayed on startup of the software: "The catalog will be updated to new version, do you want to continue?" |
| 983947 | Added proper feature tracking to several functions that were not being tracked properly |
| 1006979 | When storing symbol catalogs in a ProjectWise Managed Workspace the Insert Symbol dialog took extra time to open. |
| 998428 | In the options->wiring diagram settings->Devices tab->click build expression, in the build expression dialog, turn off the Use single column expression and update the wiring diagram. If you then right clicked on the updated wiring diagram symbol the context menu was missing the proper commands. |
| 1009584 | An extra "Example" WorkSpace was delivered with the product that didn't contain any information and has been removed now. |
| 1000575 | The Configure Databases dialog and the Configuration Variables dialog were not properly localized |
| 999571 | Changing the locked state of a configuration variable in the Configuration Variables dialog was not saved when the dialog was closed |
| 1006138 | When switching from one project to another in the Project Manager, the tooltip doesn't properly update to reflect the project database that the project belongs to |
| 997407 | The help button in the Configuration Assignment Utility failed to open the related help topic. |
| 1004922 | When integrated with ProjectWise, the copy project dialog's WorkSpace and WorkSet fields were blank by default |
