| Defect Number | Description |
| 5158 | The "Wire Use" toolbar button was not given the proper name in the "Wiring" toolbar. |
| 5312 | The page create VBA method was failing in a x64 platform |
| 5642 | Panduit help button links to the wrong help topic |
| 6049 | Selecting File>Close and then browse to open another file results in a software crash |
| 6101 | During software Installation a "Please wait while updating..." dialog is awkwardkly positioned and is overlapped with another dialog |
| 6163 | Wire Layer Configuration, Field Settings, Data Manager, & Edit Wires - Line style setting should be renamed to "By Level" instead of "ByLayer." |
| 374111 | Fixed inconsistent capitalization in the Search dialog's column headings. |
| 380163 | The Substation icon should appear in the corner of the Region Editor and Region Connection Editor and PLC Generator -> Import/Module Select/Setup/Duplicate Check dialogs |
| 423435 | Undo of Insert Symbol leaves orphan records |
| 433415 | Corrected the capitalization of "Substation" in the installation dialog |
| 446153 | Pasting Korean text into our text dialogs fails. |
| 447781 | [Cable Manager]The description in the Cable Manager dialog needed to be updated to properly explain the feature. |
| 477380 | The Bentley logo in the report templates named with "letter" should be updated to the new Bentley logo |
| 488659 | The user option profile displayed in Setup -> System Paths is different than the one referenced in the Options -> User options dialog. |
| 488660 | In the "Part Number Settings" dialog the word“part database” should be changed to “parts database” for consistency. |
| 491011 | If you make a change to a sheet model and click undo it disconnects the master model's data from the database. |
| 539545 | [SimpChinese]Without changing anything in the Wire Link Usage dialog, the "Star group and Multi-reference group" wire link will be changed to Pair type |
| 613395 | Error with deleting wire on an offline page |
| 623023 | Export to FBX format is missing from the File>Export menu |
| 636493 | An error appears when enabling the Wiring Diagram 'Dynamically update connections' toggle in the Devices tab with no page open |
| 645681 | "Cable" Placement Method description is wrong in the Help file |
| 666158 | When creating a new database it fails to create the user named 'Ecaduser' and it’s too slow to switch the SQL Server user to another user in the Setup dialog. |
| 693906 | Performing a Select All operation with focus set to the Project Manager selects all objects on the open page instead of the records in the Project Manager. |
| 695495 | Usability: Catalog Paths dialog has wasted space preventing all catalog paths from being seen without scrolling |
| 698570 | [Terminal Manager]Terminal Pin Plug Manager Timeout error can occur with certain terminal strips. |
| 700852 | [Options]The existed address files are duplicated after creating a new address file |
| 729975 | [Project Publisher] Product name promis-e under Format -> Level Display is wrong |
| 731155 | [PW] It popups error dialog when creating a new page using the projectcatalog in PW. |
| 733187 | Odd Lightning Protection shapes are sometimes generated with lightning masts |
| 737464 | Drawing modes and attributes are untranslated and need to be made localizable |
| 743998 | Data Manager error when using Replicated Database, UI Error Message: Column name or number of supplied values does not match table definition |
| 748305 | [Seed file]Updated default seed files shipped with the product to provide more useful seed files |
| 748393 | [ReportTemplateDesigner] unhandled exception occurs when open the template ‘Cable Spares - Drawing’ in the Report Template Designer |
| 752576 | [API Documentation]Clarified documentation of the LTSymbol.Modify method. |
| 752578 | [API Documentation]Documentation for InsertedEntities says in the remarks section. |
| 752711 | [ShortestDistance] Internal error No.201 occurs when you run shortest distance |
| 754196 | [API Documentation] Missing documentation for LTConnectionPoint class |
| 754198 | [API Documentation] Missing documentation for LTDiagonal class |
| 754199 | [API Documentation] Missing documentation for LTDrawing class |
| 754201 | [API Documentation] Missing documentation for LTExecutor class |
| 754203 | [API Documentation] Missing documentation for LTObject class |
| 754206 | [API Documentation] Missing documentation for LTWireNumber class |
| 754487 | [API Documentation] Documentation is required for enums and their enumerators in ECT.ECAD.API.LT namespace |
| 754490 | [API Documentation] LTField.Insert() method is not documented. |
| 754579 | [API Documentation] There are mistakes in documentation of LTProject.Descriptions and LTPage.Descriptions |
| 754860 | Cannot save or make modifications to a catalog shared on the network. |
| 767750 | An invalid prompt is displayed when we edit a parts database name and click Next in the Edit Parts Database dialog |
| 769077 | [Insert Symbol by Device ID]The first symbol cannot preview in the Insert Symbol by Device ID dialog. |
| 769736 | [Project Manager] The Add to Favorites and the Remove from Favorites commands should not display at the same time |
| 771582 | [Panduit: Button Table Editor] The added button table is not shown in the Panduit table list when we try to select a Panduit part number. |
| 771595 | [Panduit: Index Table Editor] Click Panduit button reports error if we add data in the newly created Panduit table dialog. |
| 774583 | [Panduit] The opened Panduit part table is not always the one which I selected. |
| 779386 | [Restore Project] It reports an internal error when restoring a specific project |
| 785039 | There should be a help button in the Wire Sizing Database Editor dialog. |
| 792481 | [Parts Database] Hydraulic_Symbol and Pneumatic_Symbol fields should be removed from Parts database and not displayed in the Parts Database Manager |
| 793921 | [DinRail] Missing Din Rail part number “ER – 15P” and Din Rail catalog “DIN” in JIC/IEC |
| 799076 | In the Options>Validation Prompts enable the toggle 'Run engineering design considerations check when closing page' and toggle on the specific checks you want performed. After clicking OK it does not save or remember the checks that you had specified. |
| 799398 | [Parts Database Manager] Some capitalization needs to be adjusted in the dialog |
| 809449 | An error appears while plotting all pages in the SBLP_CONSTRUCTION project |
| 863067 | An exception error occurs when opening the Insert Symbol by Partnumber dialog if the Discipline field is missing from the part database. |
