| Defect Number | Description |
| 909082 | Using the Symbol Creation Wizard to redefine the insertion point of an existing symbol could result in a software crash. |
| 857450 | The Auto Wire Number dialog was displayed several times when running auto wire numbering by selecting objects. |
| 866840 | An error appears when selecting the Manage -> Wire Sizing Database Editor tool. |
| 808373 | When using an academic license the "Academic Use Only" watermark was not being displayed on printed drawings. |
| 722704 | Some Substation elements can be deleted using MicroStation mode even though they cannot be moved. The elements should have been locked and prevented from being deleted. |
| 860973 | The project icon was not shown on WorkSets configured as a valid Substation project until you selected that WorkSet. Now they are updated in the background in a separate process. |
| 865543 | In certain scenarios an error dialog was displayed when attempting to update wiring diagram symbols. |
| 873309 | When a new hook point is added to a symbol in the Symbol Creation Wizard the hook point was not recognized as a valid hook point. |
| 856165 | When you attempted to backup a project using Windows 7 you would receive an error "ODBC-connection to '{SQL Server}(local)\BENTLEYECAD' failed." |
| 868577 | Project Manager was slow to select 3D layout pages that had a large number of references. |
| 869425 | It was slow to open 3D layout pages because it was performing an unnecessary update page command on any project that was restored from a backup file. |
| 898514 | When creating a new 3D layout symbol using Parametric Solids the symbol graphics would be shifted from the insertion point when the symbol was inserted. You also could not modify this symbol once it was created because the graphics became corrupted and could not be selected. Now we convert the Parametric Solid to a Smart Solid when we save the symbol to avoid these issues. |
| 19497 | Using the Pick Mast tool in the Lightning Protection dialog in a TOP view was not returning the highest Z coordinate and would result in an error. |
| 812452 | When integrated with ProjectWise using the Project Manager to switch from one project to another did not properly update the configuration and thus opening a page in the second project and right clicking on a symbol displayed an error dialog. |
| 476836 | Some text was truncated in various dialog boxes in the Simplified Chinese build. |
| 894758 | In the Options>Project options -> Part Number Settings dialog the Part type list was empty. |
| 617702 | The software could not execute the command "Import Construction Drawings To Project" in a project residing in a ProjectWise repository. |
| 804165 | When integrated with ProjectWise using Delete Page would display the check in dialog even when you set the variable ELEC_SHOW_PWCHECCKIN_DIALOG=False. |
| 685656 | Some text in the Parts Database Manager->Customization dialog were not localized for other languages. |
| 884344 | The software could not generate the Lightning Protection surface for a single mast in the model. |
| 885017 | The Apply button should be activated while editing values in the Options -> Project options -> Part Number Settings -> General Equipment/Part Number Exchange Preferences grid. |
| 885064 | In the Replace -> Exchange Equipment Number dialog you can right click on the column headings and add additional parts database fields to the dialog, but when you close and reopen the dialog it doesn't remember to display these columns. |
| 875769 | Lightning Protection failed to unite surfaces when an overhead cable was oriented in a particular direction. |
| 854589 | The Import Drawings feature in the Project Manager cannot properly import drawings located within a ProjectWise repository. The imported drawings did not contain any data. |
| 804242 | Some Substation attributes that are mapped to ProjectWise attributes do not display their values in ProjectWise Explorer. |
| 872714 | The Options>Wire Diagram Settings> Build Expression dialog had text that could not be localized in other languages. |
| 806383 | The page properties cannot display in the ProjectWise Explorer properties tab if the page is imported from the file system. |
| 445295 | The level that balloons were on changed to active level when the page was reopened. |
| 866915 | If you used the Project Database Utility to create a new project database using SQL Server Authentication and then applied this database to the current project the software would display the Project Database Utility a second time even though you never intended to open it again. |
| 874085 | The Place Grounding Grid tool could not be used in the Simplified Chinese version. |
| 799570 | When integrated with ProjectWise if you deleted a project it left behind the drawing files in the ProjectWise repository. If you attempted to reconfigure the remaining WorkSet as a project again you got an error message. |
| 786064 | Open a drawing from ProjectWise Explorer and when prompted with the New/Modify project dialog specify the project database connection and click Apply. The project options path will change after clicking the Apply button to the wrong path. |
| 861833 | The software could not delete the 3D objects that were created and Modified in the Symbol Creation Wizard. |
| 865023 | The software could not open the related help file in the Create Symbol->Array dialog. |
| 865208 | Shortest Distance routing failed when the project was stored in a ProjectWise repository. |
| 896721 | An API error would be displayed when creating a page with a title block that included the variable "Page.DataCreated." |
| 816332 | When integrated with ProjectWise, after copying a page to the same project the Project Manager was unable to display the copied page in the project manager details tab. |
| 865219 | An error occurred when you would open the Region Connections Editor dialog on a project stored in a ProjectWise repository. |
| 864916 | In localized versions of the software the Balloon type selection did not function properly and always created a circle balloon regardless of the balloon type that you selected. |
| 867202 | Opening the Gauge Table Editor dialog displayed an error if you connected to the SQL project database using the SA account. |
| 861091 | When marking a project as a favorite the project should have been listed at the top of the list of projects to make it easier to find. |
| 866189 | The software could not open the related help file in the 3D Box Settings dialog that is displayed when placing a panel layout device that didn't have a symbol specified for the part number you are placing. |
| 866190 | The software could not open the related help file in the Symbol Text>Add Attribute dialog. |
| 866272 | Sometimes attribute values could not be displayed in ProjectWise Explorer using the default type and environment. |
| 815063 | An error was displayed when selecting symbols on a page stored in a ProjectWise repository and then selecting the Display>Part Number tool. |
| 378668 | All the drawing files were still displayed in the Import Drawings dialog even after deleting them from the ProjectWise folder that the Import dialog was reading from. |
| 723090 | Some text strings in the Run Report>Sorting and filtering dialog were not localizable in other languages. |
| 864887 | In a localized version of the software setting the catalog path variable to "Append" and then adding a new catalog path was overwriting the existing catalog paths rather than appending to them. |
| 872762 | Some text strings in the Data Manager dialog were not localizable in other languages. |
| 872770 | Some text strings in the Substation Object Manager dialog were not localizable in other languages. |
| 872751 | Some text strings in the Wiring Manager dialog were not localizable in other languages. |
| 875793 | Coping the 3D Layout Page in this example project to a new project results in an error message when you attempt to open the copied page. |
| 898515 | The symbol creation seed files set the active level to ECT_DGRM_XREF_TEXT when they should have been set to Default. |
| 868578 | Restoring certain projects could result in a database error pertaining to the ACK table. |
| 819454 | The Tool Settings dialogs for certain commands truncated the title bar such as Draw Wire or Insert Cable/Bus Object. |
| 816274 | When trying to mark a ProjectWise project as a favorite an error would occur. |
| 868200 | Some help file links such as Help -> What's New -> CONNECT Edition and File> Help ->Readme> Installation -> Minimum Profile contained links to other MicroStation help files rather than Substation help files. |
| 816891 | If you used the Clear Page function on a page of a ProjectWise project the preview control in the Project Manager would still display the page with the previous contents rather than showing a blank page. |
| 816033 | The software could not open the related help file in the ProjectWise Configuration dialog. |
| 896625 | The User1-10 wire properties dialog displayed these property names with an extra space compared to how these same properties are displayed in other dialog boxes. |
| 817381 | When attempting to place a hook point in a ProjectWise project an erroneous information dialog would first be displayed. |
| 810035 | The title of the Project API Builder dialog was renamed to "Run Project API Builder"to avoid confusion with the other Project Builder feature. |
| 872753 | The Auto Wire Number > More Properties dialog had text that could not be localized in other languages. |
| 776885 | A stored procedure for clearing part numbers from a page was found to be written inefficiently and caused a performance issue. The stored procedure has now been optimized. |
| 817881 | When integrated with ProjectWise the PLC Generator was unable to load. |
| 872773 | A column in the Catalog Manager could not be localized in other languages. |
| 633589 | Lightning protection results were persisted on a user basis instead of stored with the project they pertain to. Now the last used settings are stored with the project. |
| 770991 | If you moved the cursor in the Delivered Configuration edit box when installing the software it could crash the installation wizard. |
| 771069 | The Launch activation wizard toggle in the installer was not opening the License Activation Wizard. |
| 765813 | When attempting to open a drawing of a different WorkSet that is not active you were prompted with a Mismatch Alert dialog. When you selected the second radio button you were no longer able to switch back to the first radio button in the dialog. |
