| Defect Number | Description |
| 977139 | The settings you specified in the Default Database dialog were lost the next time you restarted the software. |
| 980734 | You were unable to edit an existing parts database configuration in the user interface as the Edit button had no effect. |
| 977095 | After restoring a project, right clicking on a page of this project In the Project Manager disabled a context menu with most commands disabled. |
| 980738 | When you attempted to delete the default parts database configuration no warning message was displayed. |
| 952391 | Lightning Protection failed to unite shapes when an overhead cable was oriented in a particular direction |
| 900539 | The "Archive in ProjectWise" and "Move Project To File System" commands were missing from the right click menu in the Project Manager when integrated with ProjectWise. |
| 947330 | Exiting Substation after opening a page of a project in ProjectWise took several minutes |
| 857405 | If one user created a family in a shared catalog on the network, other users were unable to use it. |
| 854534 | Project Builder was unable to work with projects in a ProjectWise data source |
| 965468 | The software sometimes could crash after creating multiple new WorkSets in succession and then trying to use the Restore Project feature to browse to a backup file |
| 965466 | After creating a new WorkSet, existing projects could become disabled in the Project Manager so that you could not open them until restarting the software. |
| 947354 | Every time a Substation drawing file was opened from ProjectWise we copied out the managed workspace files even if they still existed in the local DMS folders. |
| 979541 | When creating a new project, creating a new WorkSpace or WorkSet for the project caused the pick lists to become corrupted and not list the expected values |
| 979467 | Projects created using Project API Builder was not properly associated with the selected WorkSet |
| 961019 | Changes to the Drawing Naming Convention in the options dialog did not update pages in ProjectWise |
| 960307 | After creating several new projects each of them with their own project database and separate WorkSet you might get the following error when trying to create a page in the last created project: “Unable to create new page. Another page with this same file name may already exist." |
| 948150 | When a grouped macro was deleted the wire number and cross reference graphics were left behind |
| 944988 | Macros created while in one project were sometimes unavailable when switching to a different project |
| 944405 | Projects marked as a favorite lost their favorite status after opening a page from the project |
| 977654 | After modifying a part record in the Parts Database Manager that was used in the current project, selecting the Show Differences tool could result in an error. |
| 927364 | Feature tracking was not working properly on symbol and wire right click context menus |
| 980088 | The New Project>Database dialog was not defaulting to the default project database settings |
| 980118 | After creating a new WorkSpace and WorkSet and restarting the software to load these the Configuration Variables dialog did not display the expected paths to this WorkSpace / WorkSet |
| 983291 | If your WorkSpace was shared on a network drive any new macro you created could not be inserted |
| 982031 | When you have created projects in different WorkSpaces / WorkSets and you open a page from a project it was loading the currently active WorkSpace / WorkSet instead of the one the project belonged to. |
| 979546 | Various validations were missing when attempting to connect to the SQL Server project database to notify the user of any connection errors |
| 985148 | Symbol catalogs that contained a Chinese character in the name could not be properly loaded |
| 965898 | Clicking the Modify Catalog Path button in the Catalog Manager failed with an error message |
| 979581 | Creating multiple projects with pages and then drawing a wire, before creating another project and page resulted in a "No WorkSet" Alert being displayed |
| 948240 | Replace title block for a project stored in ProjectWise only replaced the current page even when you elected to replace the entire project or selected pages |
| 936117 | Placing named boundaries to create multiple section cuts would only apply a title block to one of the section cuts instead of all of them |
| 980172 | Creating a new project in a different WorkSpace / Workset than the default one and creating a new page resulted in a Mismatch Alert dialog |
| 954726 | If you attempt to create a macro and save it to the same name as an existing macro the message that was displayed gave a control name rather than the name of the macro and if you chose to overwrite the original macro the new macro could not be inserted. |
| 911684 | The Publish I-model feature failed with an error protecting file message |
| 947051 | After inserting a symbol on a page and then launching Symbol Creation Wizard to create a new symbol, the symbol you previously inserted became corrupted in a manner that you could no longer right click on it and access the context menu. |
| 939183 | After deleting grounding grid with 3-wire connectors and 4-wire symbols, the software still lists them in the BOM report |
| 946601 | When you configured a network workspace the software displayed an unexpected configuration variables dialog on startup as if it could not find the WorkSpace paths even when it was properly specified |
| 923649 | Project Manager's Template Manager was unable to save to a ProjectWise project without an error appearing |
| 947079 | PLC Generator takes a long time and then prompts an error when generating drawings |
| 948173 | If you had opened a page of one project in ProjectWise and then attempted to open a page of a different project from ProjectWise you got an error that the page could not be found |
| 916003 | When integrated with ProjectWise, modifying variables in the Configuration variables dialog could result in an error |
| 344495 | If you delete the default project database from your configuration you now get a message indicating you must enter a default database |
| 932244 | After deleting all symbols in a location and refreshing the Location list in the Project Manager, the location description fields become duplicated |
| 945118 | When revision control is enabled and you incremented a revision the revision dialog was displayed a second time |
| 816664 | A convert potential error occurred when attempting to restore a backup of a particular project |
| 963795 | Copying a symbol from the drawing to the clipboard and then pasting it on the same drawing results in the name of the pasted instance changing to a different symbol name |
| 961651 | The Update Symbol command failed with the error, "Length cannot be less than zero." |
| 941899 | An error appeared with inserting the macro "SHLDNC" |
| 971202 | When multiple users were working in the same shared WorkSpace and one user exited and tried to restart the software it would sometimes fail to start |
| 921237 | The text position command was terminated when you changed Accusnap or Locks |
| 971144 | The description at the top of the Restore Project dialog was clarified |
| 989582 | Tooltips were missing from the "Add Catalog Path" and "Delete Catalog Path" buttons in the Catalog Manager |
| 956340 | When using the Project Search box to find a project you could not open a page of the project you searched for. This search function was deprecated now since you now have a Tree control to browse for project files. |
| 1007968 | In the Chinese version the context menu was missing the 'Navigate' option when right clicking on a component. |
| 957388 | With a page opened from ProjectWise you were unable to close the Exchange Equipment Number dialog without getting an error message |
| 954229 | The Right Arrow button was missing in the Project Publisher>Format > Build Order table dialog which prevented you from adding entries to the list |
| 938567 | The software did not rotate the drawing to Top View automatically when placing grounding grid on a DTM composed of a point cloud. |
| 945533 | When you specified a page description value during the page copy command the copied page did not maintain the specified page description |
| 957923 | The help button failed to call out the help file in the Exchange Equipment Number >Exchange Results dialog. |
| 988659 | The software should remember the Lightning Protection dialog's last position and allow resizing |
| 816067 | An error would occur when you reopened a page that has a reference file from another database |
| 951819 | Our template workset delivered a hard coded path to a configuration file that overrided the msconfig.cfg |
| 952485 | If you selected a WorkSet that was not configured with a project database connection and tried to access Command Protection settings you got an error |
| 933317 | When configuring ProjectWise component indexing if you got the message box, "Unable to configure Component Indexing" it referenced the wrong application name |
| 935500 | Focus was taken away from the Project Manager when you configured a WorkSet with a Substation project database |
| 984848 | The tooltip for the "Modify Catalog Paths" button in the Catalog Manager was updated to match the title of the dialog that is displayed |
| 977089 | The right click context menu in the Project Manager was missing some command icons |
| 728778 | CONNECT Advisor displayed items about other products in the search results |
| 728774 | The search results when using boolean expressions (And, Or, Not) were incorrect in CONNECT Advisor |
