| Defect Number | Description |
| 5158 | The "Wire Use" toolbar button was not given the proper name in the "Wiring" toolbar. |
| 5312 | The page create VBA method was failing in a x64 platform |
| 5642 | Panduit help button links to the wrong help topic |
| 6049 | Selecting File>Close and then browse to open another file results in a software crash |
| 6101 | During software Installation a "Please wait while updating..." dialog is awkwardly positioned and is overlapped with another dialog |
| 6163 | Wire Layer Configuration, Field Settings, Data Manager, & Edit Wires - Line style setting should be renamed to "By Level" instead of "ByLayer." |
| 374111 | Fixed inconsistent capitalization in the Search dialog's column headings. |
| 380163 | The application icon should appear in the corner of the Region Editor and Region Connection Editor and PLC Generator -> Import/Module Select/Setup/Duplicate Check dialogs |
| 423435 | Undo of Insert Symbol leaves orphan records |
| 446153 | Pasting Korean text into our text dialogs fails. |
| 447781 | [Cable Manager]The description in the Cable Manager dialog needed to be updated to properly explain the feature. |
| 477380 | The Bentley logo in the report templates named with "letter" should be updated to the new Bentley logo |
| 488659 | The user option profile displayed in Setup -> System Paths is different than the one referenced in the Options -> User options dialog. |
| 488660 | In the "Part Number Settings" dialog the word“part database” should be changed to “parts database” for consistency. |
| 491011 | If you make a change to a sheet model and click undo it disconnects the master model's data from the database. |
| 539545 | [SimpChinese]Without changing anything in the Wire Link Usage dialog, the "Star group and Multi-reference group" wire link will be changed to Pair type |
| 613395 | Error with deleting wire on an offline page |
| 623023 | Export to FBX format is missing from the File>Export menu |
| 636493 | An error appears when enabling the Wiring Diagram 'Dynamically update connections' toggle in the Devices tab with no page open |
| 645681 | "Cable" Placement Method description is wrong in the Help file |
| 666158 | When creating a new database it fails to create the user named 'Ecaduser' and it’s too slow to switch the SQL Server user to another user in the Setup dialog. |
| 693906 | Performing a Select All operation with focus set to the Project Manager selects all objects on the open page instead of the records in the Project Manager. |
| 695495 | Usability: Catalog Paths dialog has wasted space preventing all catalog paths from being seen without scrolling |
| 698570 | [Terminal Manager]Terminal Pin Plug Manager Timeout error can occur with certain terminal strips. |
| 700852 | [Options]The existed address files are duplicated after creating a new address file |
| 729975 | [Project Publisher] Product name promis-e under Format -> Level Display is wrong |
| 731155 | [PW] It popups error dialog when creating a new page using the projectcatalog in PW. |
| 733187 | Odd Lightning Protection shapes are sometimes generated with lightning masts |
| 737464 | Drawing modes and attributes are untranslated and need to be made localizable |
| 743998 | Data Manager error when using Replicated Database, UI Error Message: Column name or number of supplied values does not match table definition |
| 748305 | [Seed file]Updated default seed files shipped with the product to provide more useful seed files |
| 748393 | [ReportTemplateDesigner] unhandled exception occurs when open the template ‘Cable Spares - Drawing’ in the Report Template Designer |
| 752576 | [API Documentation]Clarified documentation of the LTSymbol.Modify method. |
| 752578 | [API Documentation]Documentation for Inserted Entities says in the remarks section. |
| 752711 | [ShortestDistance] Internal error No.201 occurs when you run shortest distance |
| 754196 | [API Documentation] Missing documentation for LTConnectionPoint class |
| 754198 | [API Documentation] Missing documentation for LTDiagonal class |
| 754199 | [API Documentation] Missing documentation for LTDrawing class |
| 754201 | [API Documentation] Missing documentation for LTExecutor class |
| 754203 | [API Documentation] Missing documentation for LTObject class |
| 754206 | [API Documentation] Missing documentation for LTWireNumber class |
| 754487 | [API Documentation] Documentation is required for enums and their enumerators in ECT.ECAD.API.LT namespace |
| 754490 | [API Documentation] LTField.Insert() method is not documented. |
| 754579 | [API Documentation] There are mistakes in documentation of LTProject.Descriptions and LTPage.Descriptions |
| 754860 | Cannot save or make modifications to a catalog shared on the network. |
| 767750 | An invalid prompt is displayed when we edit a parts database name and click Next in the Edit Parts Database dialog |
| 769077 | [Insert Symbol by Device ID]The first symbol cannot preview in the Insert Symbol by Device ID dialog. |
| 769736 | [Project Manager] The Add to Favorites and the Remove from Favorites commands should not display at the same time |
| 771582 | [Panduit: Button Table Editor] The added button table is not shown in the Panduit table list when we try to select a Panduit part number. |
| 771595 | [Panduit: Index Table Editor] Click Panduit button reports error if we add data in the newly created Panduit table dialog. |
| 774583 | [Panduit] The opened Panduit part table is not always the one which I selected. |
| 779386 | [Restore Project] It reports an internal error when restoring a specific project |
| 785039 | There should be a help button in the Wire Sizing Database Editor dialog. |
| 793921 | [DinRail] Missing Din Rail part number “ER – 15P” and Din Rail catalog “DIN” in JIC/IEC |
| 799076 | In the Options>Validation Prompts enable the toggle 'Run engineering design considerations check when closing page' and toggle on the specific checks you want performed. After clicking OK it does not save or remember the checks that you had specified. |
| 799398 | [Parts Database Manager] Some capitalization needs to be adjusted in the dialog |
| 809449 | An error appears while plotting all pages in the SBLP_CONSTRUCTION project |
| 863067 | An exception error occurs when opening the Insert Symbol by Partnumber dialog if the Discipline field is missing from the part database. |
| 476836 | Some text was truncated in various dialog boxes in the Simplified Chinese build. |
| 685656 | Some text in the Parts Database Manager->Customization dialog were not localized for other languages. |
| 885017 | The Apply button should be activated while editing values in the Options -> Project options -> Part Number Settings -> General Equipment/Part Number Exchange Preferences grid. |
| 885064 | In the Replace -> Exchange Equipment Number dialog you can right click on the column headings and add additional parts database fields to the dialog, but when you close and reopen the dialog it doesn't remember to display these columns. |
| 872714 | The Options>Wire Diagram Settings> Build Expression dialog had text that could not be localized in other languages. |
| 445295 | The level that balloons were on changed to active level when the page was reopened. |
| 378668 | All the drawing files were still displayed in the Import Drawings dialog even after deleting them from the ProjectWise folder that the Import dialog was reading from. |
| 723090 | Some text strings in the Run Report>Sorting and filtering dialog were not localizable in other languages. |
| 872762 | Some text strings in the Data Manager dialog were not localizable in other languages. |
| 872770 | Some text strings in the Substation Object Manager dialog were not localizable in other languages. |
| 872751 | Some text strings in the Wiring Manager dialog were not localizable in other languages. |
| 810035 | The title of the Project API Builder dialog was renamed to "Run Project API Builder" to avoid confusion with the other Project Builder feature. |
| 872753 | The Auto Wire Number > More Properties dialog had text that could not be localized in other languages. |
| 776885 | A stored procedure for clearing part numbers from a page was found to be written inefficiently and caused a performance issue. The stored procedure has now been optimized. |
| 771069 | The Launch activation wizard toggle in the installer was not opening the License Activation Wizard. |
| 781648 | During a Move To Database operation, there was a timeout error while records were being deleted from the source database which left the ect.fid file pointing at the source database instead of the target database. |
| 813691 | The application was holding a lock on the multi-language.mdb file in situations where it no longer needed one. In a multi-user environment this could eventually lead to lock outs of other users not being granted access. |
| 791842 | We no longer build the connection list when restoring a project |
| 795008 | General query optimizations were made to the Project database |
| 795138 | Improved performance of page copy |
| 800448 | Corrected performance issues with manipulating MicroStation elements |
| 800449 | Improved performance of drawing a wire that crosses other wires |
| 869972 | Device IDs could become scrambled after performing Copy Page(s) |
| 895787 | ProjectWise Check in should only include references/rasters that were activated while working on the master file. |
| 898107 | ProjectWise check in process was inconsistent depending on whether you directly closed a page or opened another page to close the current page. |
| 898800 | ProjectWise check in process should provide a second check in dialog for any attached raster file, the same as MicroStation. |
| 899263 | ProjectWise integration should check-in the raster file even if the raster file is outside of the project folder. |
| 754860 | Cannot save or modify content to a catalog shared on a network drive. |
| 974461 | Project API Builder should accept the newer Excel File format ".xlsm" for the instruction file. |
| 693252 | The "Save files in AutoCAD compatible format" check box was removed from the Backup Project dialog since the AutoCAD version has been deprecated. |
| 671453 | When opening a report template from the Report Template Designer some Substation Grounding Grid reports were listed in Promis.e by mistake and have now been removed from the pick list. |
| 671450 | In the Terminal Manager if you right clicked to rename a location the dialog contained a label that was not properly localized. |
| 134840 | The customize menu button was missing from the software. In CONNECT Edition, you can simply right click on the ribbon menu. |
| 5021 | Fixed attribute name inconsistency in the Data Manager |
| 25290 | Project Manager tool tip messages are not localized |
| 49321 | ProjectWise integration: Auto check in/out of all reference files |
| 78121 | Project API Builder, Import Spreadsheet Into BOM are not accepting XLSX & XLSM files |
| 82380 | Project Publisher and Export To DWG should remove escape backslashes added by the software |
| 365907 | User name appears in the User column in Project Manager even though the page is not open. |
| 492097 | UNDO move disconnects symbols in other modes |
| 703448 | Terminal Pin Plug Manager Timeout error occurred when trying to load a particular terminal strip in the project |
