| Product(s): | ProSteel | ||
| Area: | Detail Style | ||
| Subarea: | Default Settings tab | ||
This section contains the information related to Default Settings tab of Detail Style of ProSteel CONNECT Edition. This is the tab for global default settings ranking higher than all other tabs. If, for instance, dimensioning is deactivated, no dimensioning will be carried out - independent of what has been indicated in the individual dimensioning tabs.
