| Product(s): | ProSteel | ||
| Area: | Detail Center Standard | ||
| Subarea: | General | ||
I'm running into an issue in ProStructures when creating a 2D sheet from the Detail Center. In my preview the object displays correctly, but when I "Insert 2D" my MC channels are displaying incorrectly. Has anybody experienced/resolved this issue? I've only noticed this issue on my MC channel so far, in this case it's MC10x33.6.
Channel in preview:
Channel on sheet:
It is replicable when we insert channel part drawing or any drawing which has curve in the 2D Design Model.
Enter methods to resolve in this section.
1. Create a 3D Design Model.
2. Now, insert the 2D drawing in this 3D Design Model, here you will get the correct drawing, please refer to the below image.
3. Then reference this 3D Design Model to your Sheet model.
