| Product(s): | ProSteel | ||
| Area: | Drawing Production | ||
| Subarea: | Detail Center Standard | ||
After Creating drawings for the Bracing shapes, when users try to place the drawing into the sheet model, they may not be able to see the Turn Buckle of the bracing visible in the sheet model. (Refer to the Image Below)
In this wiki, we will learn how to resolve this issue step by step.
Turn Buckle of the bracing in the sheet model or while printing because the sheet model set into the 2D format. Follow the steps below to know this issue can be resolved.
1. Navigate to the models’ option and under it click on ‘Create a new model’.
2. Select the model type as ‘Sheet Model’ and set its format as 3D.
3. After the creation of the sheet model, place the same bracing drawing into the new sheet.
Now, you will observe that the ‘Turn Buckle’ of the bracing is visible in the sheet model and also in the print preview.
In this way, this issue can be resolved.
