| Product(s): | Promise CONNECT | ||
| Version(s): | 10.00.XX.XX to 10.03.XX.xx | ||
| Area: | Installation_Configuration | ||
| Subarea: | N/A |
The program folder contains the basic executable files and program libraries required to make Promis.e CONNECT run. This path is specified during installation and cannot be altered afterward.
For Promise ANSI-IEEE Example
C:\Program Files\Bentley\Promise CONNECT Edition\Promise
| Original Author: | Satish Saptasagar |
