| Product(s): | Bentley Substation | ||
| Version(s): | through 10.01.00.23 | ||
| Area: | Installation_Configuration | ||
| Subarea: | N/A |
The program folder contains the basic executable files and program libraries required to make Bentley Substation run. This path is specified during installation and cannot be altered afterward.
For Substation ANSI-IEEE Workspace
C:\Program Files\Bentley\Bentley Substation CONNECT Edition\Substation
Note: Remove "(x86)" from the path for 32-bit operating systems.
C:\Program Files (x86)\Bentley\Substation V8i\Substation
| Original Author: | Matt_P |
