| Product(s): | ProSteel | ||
| Area: | Detail Center Standard | ||
| Subarea: | N/A | ||
Users may face this problem in that the connections and their groups in the model are not visible in the Detail Center Standard.
This wiki will help you to resolve this issue. Please follow the steps below.
1. Under the Steel workflow, navigate to the Drawing Production> Detail Center Standard.
2. Once the Detail Center is opened, click on the settings tab.
3. Under the settings tab, check the option ‘Scan Joints’.
4. This will scan all the connections/joints in the model and they will appear under the parts tab.
