| Product(s): | ProSteel for AutoCAD | ||
| Area: | Data/Reporting | ||
| Subarea: | Positionflags & Positioning | ||
This section contains the wikis related to the ProSteel Positionflags & Positioning tool of ProSteel CONNECT for AutoCAD. This tool used to create or automatically generate position numbers and flags for parts in a 3D model for final detailing and can be accessed from ProStructures menu > Positioning > Positioning.
Command: PS_POS
