| Product(s): | ProSteel for AutoCAD | ||
| Area: | ProSteel Positionflags & Positioning | ||
| Subarea: | Automatic Positioning | ||
This Wiki will guide you on how to process numbering of the parts and assign Position Numbers automatically for the steel objects in ProSteel for AutoCAD.
1. Go to ProStructures menu > Positioning > Positioning.
OR
Type PS_POS in the command line and hit Enter to open ProSteel Positionflags & Positioning dialog.
2. Now, go to the Steel Positioning tab.
3. For the next steps, please follow the below wiki link of ProSteel CONNECT Edition.
WIKI: Automatic Positioning in ProSteel
In this way, you can positioning steel elements automatically in ProSteel for AutoCAD.
