| Product(s): | ProSteel for AutoCAD | ||
| Area: | Data/Reporting | ||
| Subarea: | External Partlist | ||
This section contains the wikis related to the External Partlist tools of ProSteel CONNECT for AutoCAD.
Partlist Creation
Partlist Creation tool used to generate a partlist database (*.mdb) from currently selected steel objects and can be accessed ProSteel > Edit > Create Partlist Database.
Command: PS_PARTLIST
ProStructures Partlist
ProStructures Partlist used to generate and create the output of a parts list and can be accessed ProSteel > Edit > Create Partlist.
Command: PS_CREATE_PARTLIST
