| Product(s): | ProConcrete |
| Area: | Rebar Placement |
| Subarea: | Footing Reinforcement |
| Original Author: | Kemuel Jancorda, Bentley Product Advantage Group |
| Updated By: | N/A |
This section contains the wikis related to the Footing Reinforcing tools in ProConcrete CONNECT Edition. These tools can be accessed under the Concrete workflow > Home > Rebar Placement > Footing Reinforcing (Pad/Continuous).
