| 1061380 | [Balloon] Asociation to symbol does not work. |
| 1054343 | [Balloon] Issues when place balloon in the drawing. |
| 1054320 | [Balloon] Providing 6 default styles in a DGN lib file by default (styles are missing) |
| 1054308 | [Balloon] The balloon can only be placed in the Top view in a 3D layout page (in Substation UP4 and V8i ballons can be placed in different views) |
| 1054358 | [Balloon] The software will crash if the user places a balloon for a 3D symbol with ACK part numbers. |
| 1061993 | [Balloon]The text is truncated in the Place Balloon dialog. |
| 1054307 | [Balloon]When restoring an old project with balloons, then modifying the old balloon in the schematic mode page, the software crash. |
| 807518 | [Catalog} Error generated during importing catalog due to fields values length exceeding the max length |
| 1054299 | [CatalogManager] After importing any catalog, Catalog manager refreshes all present catalogs |
| 1070074 | [Component Center] Cannot list the symbol with family details in the Insert Symbol by Device ID dialog |
| 1070221 | [Component Center] Error is generated when saving the new family to overwrite existing ones in the catalog in Component Center |
| 1055115 | [Components Center]The software will pop up CONNECTION Failed when activating the refresh button in Catalog Manager. |
| 1039713 | [Construction Drawing Manager]The grid header right-click menu is hidden by the fields list. |
| 1066584 | [LCM Properties Control]The BOM Document Number and Revision Number values cannot be assigned to a symbol. |
| 1039944 | [Modify Catalog Paths] The catalogs under the PW path are not listed in the Expansion box |
| 1062399 | [Options Balloon Settings]Balloon type and some balloon settings are removed for some pages in the options->Balloon Settings dialog. |
| 1066607 | [Options] Life Cycle Manager Settings -> Attribute values -> Add, the default value should be "Attribute Value Name", not "Attribute Name" |
| 1069328 | [Performance Project Manager] Opening the Drawing Set tab in the project manager dialog is slow |
| 810508 | [Performance] The automatic rebuild of the catalog database should not open every dgn in the catalog. |
| 1032409 | [Place Labels] BOM is not created properly when the option " Construction-ID" is checked on the construction drawing |
| 1069421 | [PW Backup]Error dialog pops up when backing up the project. |
| 1061677 | [PW Cloud] Open new page dialog copies out unnecessary files |
| 1053543 | [PW Cloud] Opening the modify page dialog is very slow. |
| 1061302 | [PW Cloud] Symbol creation fails if catalogs are stored in PW hosted environment |
| 1061699 | [PW Cloud] Symbol creation in hosted ProjectWise environment throws an exception error |
| 1053665 | [PW Cloud]Modifying the description of the location is very slow. |
| 1069627 | [PW Run Shortest Distance] Run the shortest distance in ProjectWise environment will cause the software crash. |
| 1067222 | [Report Template Design] Error dialog pops up while adding work order/life cycle status to the sorting dialog in the preview report |
| 1057210 | [Text Settings]Add an “Apply” button in the Edit Text format dialog. |
| 1054886 | [Text Settings]Modify the Device ID Text color, and then reopen the Edit Text format dialog, the color display is not correct. |
| 1054871 | [Text Settings]While selecting the Terminal/Pin-plug, the format of Symbol Text is changed. |
| 1054875 | [Text Settings]While selecting circuits with different text format for the Device ID, and changing the height in the Edit Text format dialog, the preview is incorrect. |
| 1056956 | Validate Page command didn't work in Users Project |
| 1065230 | Cross Reference is not visible |
| 1067851 | Creating a New Page and Modifying the Page tools are performing slower compared to the Update 3 |
| 198259 | LCM does not assign wire properties to new wires following the correct By Branch or By Potential process |
| 1040466 | Modify report templates to include Properties Control Variables |
| 1061786 | Opening the page in the user's project, the project will crash |
| 1034575 | Symbol creation command excludes certain 3D objects |
| 1055577 | The page sort order is not consistent for the names starting with both character and number |
| 1048772 |
The symbol creation dialog is hidden when placing a Tag Mnemonic even though the dialog was pinned open
