| Product(s): | OpenUtilities Substation | ||
| Version(s): | 08.11.07.158 - 10.06.00.22 | ||
| Area: | Database Platform Support | ||
| Subarea: | N/A |
Each version of Bentley Substation has its own corresponding project database schema, identified by a version number. The version number of the database is stored as an extended property of the Project table in SQL Server databases and as a comment on the Project table for Oracle databases.
When connecting to the project database, if the "Version" property/comment of the database does not match what Substation expects or cannot be retrieved for some reason, a [[Error - Database version does not match the application|Database version does not match the application]] message will appear. Generally this means that either the Substation application or the database schema needs to be updated, whichever is older.
Database version numbers can also be revealed in a prompt when restoring a project from a different version of Substation. In this case, when the current project database version is newer than the database version for the backup listed in the message, the message is purely informational and no action is necessary. If the database version of the backup is newer than the application, the backup cannot be restored and the message typically indicates this ([[Error - Unable to restore project, project's database version is newer|Unable to restore project because the project's database version is newer than your current database version]]).
The purpose of this document is to help determine the proper course of action, if any is necessary.
This chart applies to SELECT releases of Bentley Substation.
| Application | Application Version | Database Version |
| Bentley Substation CONNECT Edition Update 6 | 10.06.00.22 | 10.0.13 |
| Bentley Substation CONNECT Edition Update 5 | 10.05.00.35 | 10.0.11 |
| Bentley Substation CONNECT Edition Update 4 | 10.04.00.30 | 10.0.09 |
| Bentley Substation CONNECT Edition Update 3 | 10.03.00.42 | 10.0.04 |
| Bentley Substation CONNECT Edition Update 2 | 10.02.00.31 | 10.0.03 |
| Bentley Substation CONNECT Edition Update 1 | 10.01.00.23 | 10.0.02 |
| Bentley Substation CONNECT Edition | 10.00.00.232 | 10.0.01 |
| Bentley Substation V8i SS8 Refresh 2 | 08.11.13.140 | 8.1.45 |
| Bentley Substation V8i SS8 Refresh | 08.11.13.73 | 8.1.38 |
| Bentley Substation V8i SS8 | 08.11.13.52 | 8.1.33 |
| Bentley Substation V8i SS7 Refresh Q1 2015 | 08.11.12.137 | 8.1.14 |
| Bentley Substation V8i SS7 Refresh Q3 2014 | 08.11.12.89 | 8.1.12 |
| Bentley Substation V8i SS7 Refresh Q2 2014 | 08.11.12.75 | 8.1.10 |
| Bentley Substation V8i SS7 REFRESH | 08.11.12.64 | 8.1.10 |
| Bentley Substation V8i SS7 | 08.11.12.17 | 8.1.06 |
| Bentley Substation V8i SS6 | 08.11.11.14 | 8.0.72 |
| Bentley Substation V8i SS5 REFRESH | 08.11.10.26 | 8.0.71 |
| Bentley Substation V8i SS5 | 08.11.10.25 | 8.0.69 |
| Bentley Substation V8i SS4 | 08.11.09.23 | 8.0.63 |
| Bentley Substation V8i SS3 | 08.11.08.18 | 8.0.56 |
| Bentley Substation V8i SS2 | 08.11.07.158 | 8.0.51 |
The installed version of Bentley Substation (Application Version in the chart) can be found on the [[About Bentley Substation]] dialog.
The current database version can be determined by connecting to the SQL Server using SQL Server Management Studio (SSMS) and checking the extended properties of the Project table in the database used by Substation. In SSMS, expand Object Explorer > Databases > Substation* > Tables, right click dbo.Project, and select Properties > Extended Properties.
Alternatively, executing the following query will also return the database version.
use Substation
SELECT * FROM fn_listextendedproperty ('Version', 'user', 'dbo', 'table', 'project', default, default)
Replace "Substation" in the above query with the name of the database is not "Substation".
"SS" in the above chart stands for SELECTseries.
The version of the database that will be created by a script file can typically be found as a comment near the beginning of the script. For example:
--$DBVersion:8.1.33$--
Similarly, an update script will list the version to which the script will update the database.
The SQL Server and database used by Bentley Substation can be determined by looking in the Project Database area of the Substation [[Setup]] dialog.
[[How to download the Bentley Substation software]]
[[Creating and Updating the Project Database]]
[[Error - Database version does not match the application]]
[[Error - Unable to restore project, project's database version is newer]]
[[Project Database Version - promis.e]]
| Original Author: | Matt_P |
