| Product(s): | ProSteel for AutoCAD | ||
| Area: | External Partlist | ||
| Subarea: | ProStructures Partlist | ||
This Wiki will guide you on how to load existing partlist database in ProSteel for AutoCAD to print the partlist.
1. Go to ProSteel > Edit > Create Partlist.
OR
Type PS_CREATE_PARTLIST in the command line and hit Enter to open ProStructures Partlist dialog.
2. In the ProStructures Partlist dialog, go to File > Open.
3. And here select your required Partlist Database (*.mdb) file and click on the Open button.
4. Now, the entire partlist will be loaded in the ProStructures Partlist dialog.
5. Now, from here you can print the Partlist by selecting your required list file. For more information on this, please follow the below wiki link.
WIKI: How to create ProSteel Partlist?
In this way, you can load existing partlist database in ProSteel for AutoCAD to print partlist.
