| Product(s): | ProSteel for AutoCAD | ||
| Area: | General | ||
| Subarea: | PS Properties | ||
This Wiki will guide you on how to update the material grade for multiple objects in one go in ProSteel for AutoCAD.
1. Select multiple objects for which you want to change the material grade. One can use Select Similar option to choose all the similar objects within the model.
2. Once selection is done then right click and select the PS Properties.
3. Go to Partlist Data > Data, here set your required material grade and click on the OK button.
In this way, one can update the material grade for multiple objects in one go in ProSteel for AutoCAD.
