| Product(s): | Promis.e CONNECT Edition | |
| Version(s): | 10 | |
| Environment: | N/A | |
| Area: | Installation_Configuration | |
| Subarea: | N/A |
In the CONNECT Edition, the software utilizes the native Power Platform configuration system to locate the dataset, connect to the project database, and specify various default settings.
Note: Power Platform is the MicroStation core application that underlies the CONNECT Edition product.
New configuration variables have been introduced that can be set in any configuration file to configure the software. The purpose of this article is to provide a comprehensive list of the application specific variables that are used to configure the software and explain their purpose.
Application variables are prefixed with “ELEC_” to set them apart from the standard Power Platform variables.
The following table provides a complete list of the application specific variables and defines what if any dialog boxes within the software can set their values:
Variable Name |
Description |
Dialogs that Control the Variable |
ELEC_DRAWING_STANDARD |
Drawing standard (IEC vs ANSI-IEEE)
ELEC_WORKSETSTANDARDS |
Promis.e WorkSet standards folder |
ELEC_WORKSETDGNS |
Location where DGN files will be stored |
ELEC_DEFAULT_PROJECT_DIR |
The default folder that the Project Manager sets focus to |
- Configuration Variables |
ELEC_ACTIVEPARTSDATABASE |
Active parts database name |
ELEC_PARTS_DB_MAPPING_PATH |
Path to the parts database mapping file which defines the connection to the parts database |
ELEC_CATALOG_PATH |
All catalogs found in the path specified will be loaded. Users can specify multiple paths delimited by a semi-colon if they want to load catalogs from multiple locations (i.e. some catalogs on the local machine and some on a network share) |
ELEC_LANGUAGE_DB_PATH |
Path to the Multi-language.mdb file |
ELEC_SYSTEM_OPTION_PROFILE |
Path to the system option profile XML file |
ELEC_PROJECT_OPTION_PROFILE |
Path to the project option profile XML file |
ELEC_USER_OPTION_PROFILE |
Path to the user option profile XML file |
ELEC_PRJ_PROFILE_DIR |
Path to the project profiles |
ELEC_PAGE_FORMAT_DIR |
Path to the page formats |
ELEC_TEMPLATES_GRAPHICPLAN_DIR |
Path to the graphical plan templates folder |
ELEC_TEMPLATES_PAGE_DIR |
Path to the page templates folder |
ELEC_TEMPLATES_REPORT_DIR |
Path to the report templates folder |
ELEC_ENABLE_MANAGED_CONFIGURATION |
True/False variable that enables or disables the ProjectWise Managed Workspace integration Refer to the Managed WorkSpace Configuration guide for instructions on how to configure a managed WorkSpace which makes use of additional variables not discussed here. | |
ELEC_SHOW_PWCHECKIN_DIALOG |
Specifies whether the ProjectWise Check In dialog should be displayed when a file is closed or if the file should be automatically checked it in. |
These configuration variables can be set in any configuration file. To understand how these variables are used in the configuration files that are delivered with a default installation of the software, please refer to the Configuration Files article.
