| Product(s): | Promis.e | ||
| Version(s): | through 08.11.13.96 | ||
| Area: | N/A | ||
| Subarea: | N/A |
The About Promis.e dialog displays version and other information that can be helpful when seeking technical support or determining product compatibility and when upgrading is appropriate.
select Help > About Promis.e V8i
select Help > About promis-e V8i
select promis-e|Help > About promis-e V8i
select promis-e Help > About
or
Project Manager > promis-e Help > About
At AutoCAD command prompt, type:
ECAD_EXEC_ABOUT
At Standalone/MicroStation/PowerDraft Key-in dialog (Utilities > Key-in), type:
ECAD EXEC ABOUT
[[Compatibility Chart - Promis.e]]
| Original Author: | Matt_P |
Keywords: promis-e
