| Product(s): | promis.e, Bentley Substation | ||
| Version(s): | 08.11.08.XX | ||
| Area: | Component Management | ||
| Subarea: | Parts Database |
When trying to create a new part record in the [[Parts Database Manager]] with the "Apply part information from the current record to new part number" option enabled, you get an error message saying:
Warning
Invalid Operation
OK
In some cases this error has been found to be caused by incorrect values in the OID field of the parts database. If that field is blank or is a duplicate of an already existing OID value, then you could get this error. The data type for the OID field is AutoNumber, so there should be a unique numeric value for each record. AutoNumber fields cannot be renumbered.
To correct duplicate values in the OID field use the following process:
| Original Author: | Tani_S |
Keywords: 66767, 500000085365
