| Version(s): | through 08.11.13.140 | ||
| Area: | Database Platform Support | ||
| Subarea: | N/A |
Manual and automatic shrinking of SQL database data files causes index fragmentation, which leads to poor performance. Having the Auto Shrink property and the Auto Growth property enabled for a database can result in frequent shrink-grow cycles which causes file system fragmentation, adding to performance issues. To avoid this situation, disable Auto Shrink on SQL Server databases such as the project databases for Promis.e and Bentley Substation. This will stop automatic shrinking and further index fragmentation but does not fix existing fragmentation. To correct the index fragmentation use the method described in [[Re-index SQL database]] after disabling Auto Shrink and defragmenting the disk.
Note: the scripts that create and update the project database have been changed to set the AUTO_SHRINK property to OFF. This change was made for version 08.11.12.120, so depending on the history of the database, Auto Shrink may already be disabled.
This step may be optional, depending on the level of fragmentation that exists. It would need to be done when users do not need to access the databases.
See [[Re-index SQL database]]
Auto Grow, Auto Shrink and Physical File Fragmentation in SQL Server
How to: Stop an Instance of SQL Server (SQL Server Configuration Manager)
| Original Author: | Matt_P |
Keywords: autoshrink
