| Version(s): | through 08.11.12.137 | ||
| Area: | Database Platform Support | ||
| Subarea: | N/A |
Index was outside the bounds of the array (Microsoft.SqlServer.smo) while trying to edit the database in SQL Server Management Studio.
This issue occurs because of an error in SQL Server Management Studio 2008 R2
To resolve this issue, apply Cumulative Update 5 for SQL Server 2008 R2 on the computer that has SSMS 2008 R2 installed.
The fix for this issue was first released in Cumulative Update 3 for SQL Server 2008 Service Pack 2. For more information about this cumulative update package, click the following article number to view the article in the Microsoft Knowledge Base:
Note Because the builds are cumulative, each new fix release contains all the hotfixes and all the security fixes that were included with the previous SQL Server 2008 fix release. Microsoft recommends that you consider applying the most recent fix release that contains this hotfix. For more information, click the following article number to view the article in the Microsoft Knowledge Base:
Microsoft SQL Server 2008 hotfixes are created for specific SQL Server service packs. You must apply a SQL Server 2008 Service Pack 2 hotfix to an installation of SQL Server 2008 Service Pack 2. By default, any hotfix that is provided in a SQL Server service pack is included in the next SQL Server service pack.
The fix for this issue was first released in Cumulative Update 12 for SQL Server 2008 Service Pack 1. For more information about this cumulative update package, click the following article number to view the article in the Microsoft Knowledge Base:
Microsoft SQL Server 2008 hotfixes are created for specific SQL Server service packs. You must apply a SQL Server 2008 Service Pack 1 hotfix to an installation of SQL Server 2008 Service Pack 1. By default, any hotfix that is provided in a SQL Server service pack is included in the next SQL Server service pack.
The fix for this issue was first released in Cumulative Update 5. For more information about how to obtain this cumulative update package for SQL Server 2008 R2, click the following article number to view the article in the Microsoft Knowledge Base:
Note Because the builds are cumulative, each new fix release contains all the hotfixes and all the security fixes that were included with the previous SQL Server 2008 R2 fix release. We recommend that you consider applying the most recent fix release that contains this hotfix. For more information, click the following article number to view the article in the Microsoft Knowledge Base:
| Original Author: | Bhargav Chintalapati |
