| Product(s): | ProConcrete CONNECT Edition |
| Version(s): | 10.05.00.54 |
| Environment: | N/A |
| Area: | Report |
| Subarea: | Schedule Generator |
| Original Author | Sandip Kar, Product Advantage Group |
While generating Schedule of Rebars using Schedule Generator, the text sizes coming very small which are hard to read eben. Following is the output of Rebar Schedule.
This issue is coming due to the Text Style set in Options Tab of Schedule Generator. The default Text Style is Bentley
Change the Text Style to other style like ProConcrete2 or ProConcrete3 which then publish report with correct text size.
