Product(s): | Promis.e, Bentley Substation | ||
Version(s): | 08.11.12.137 | ||
Environment: | N/A | ||
Area: | Database Platform Support | ||
Subarea: | N/A |
When attempting to create a new project database with the Project Database Utility, the following error message is displayed:
T-SQL execution command line utility
T-SQL execution command line utility has stopped working
Windows can check online for a solution to the problem.
-> Check online for a solution and close the program
-> Close the program
Problem Event Name: APPCRASH
Application Name: SQLCMD .EXE
Application Version: 2014.120.2000.8
Application Timestamp: 5306c4e4
Fault Module Name: SQLCMD .EXE
Fault Module Version: 2014.120.2000.8
Fault Module Timestamp: 5306c4e4
Exception Code: c0000005
Exception Offset: 00001470
This is a Microsoft SQL Server issue, not directly caused by Promis.e or Bentley Substation. It may be caused by a Windows Update being applied without subsequently rebooting the system.
This issue was resolved by rebooting the workstation receiving the error.
Original Author: | Matt_P |
Keywords: Separate Database Per Project, Multiple Databases, Project database strategy
