Error on backup - Invalid database object reference
 Product(s):Promis.e, Bentley Substation
 Version(s):08.11.08.xx
 Environment:Oracle
 Area:Database Platform Support
 Subarea:N/A
Error or Warning Message
When trying to backup projects using Project Manager, the following error occurs:
Internal Error
Error Message: Invalid database object reference.
TargetSite: Void ExecuteSQL(Int32, System.String)
DeclaringType: MDBProxy.ConnectionManager
Attributes: internal
MemberType: Method
The software may otherwise function normally.  The problem occurs when an Oracle project database is used.
How to Avoid
Use the fully-qualified hostname for the Server Name field in the Project Database area of [[Setup]] instead of a simple host name.  The fully-qualified host name would be in the following format: hostname.domainname
For example: myhost.xyz.com
 Original Author:Matt_P
