| Version(s): | through 08.11.12.137 | ||
| Area: | Database Platform Support | ||
| Subarea: | N\A |
When trying to create a new project using Project Manager, the following error message is displayed. A folder is created but not recognized as a project folder.
Internal Error
Error Message: Exception has been thrown by the target of an invocation.
TargetSite: System.Object _InvokeMethodFast(System.Object, System.Object[], System.SignatureStruct ByRef, System.Reflection.MethodAttributes, System.RuntimeTypeHandle)
DeclaringType: System.RuntimeMethodHandle
Attributes: private
MemberType: Method
In one case this was caused by using a SQL login that did not meet the [[Minimum SQL user permissions]] for connecting the software to the project database. Specifically, the login had public, db_datareader, and db_datawriter roles, but the corresponding user had not been granted Execute permission on the database.
Follow the steps described in the [[Minimum SQL user permissions]] article.
| Original Author: | Matt_P |
