Product(s): | ProConcrete | ||
Version(s): | CONNECT Edition | ||
Environment: | N/A | ||
Area: | Reporting | ||
Subarea: | Bar Bending Schedule | ||
Original Author: | Sandip Kar, User Success Team |
Sometime user want to have Custom Bar Marks instead of Automatic Bar Marks. Using the Manual Bar Marking tool it is now possible to get the Custom Bar Marks. Now the same User Marks or Custom Bar Marks need to be populated in Bar Bending Schedule. This document will explain how we can populate User Marks in Bar bending Schedule.
In ProConcrete Bar Bending Schedule is generated using the script written in lst file. Every bar bending Schedule have different script written in lst file which users can customize according to their need. So to get the User Mark in Bar Bending Schedule, one must need to use the correct Variable/Field.
Please follow the below steps to get the User Marks in bar bending Schedule.
1. Usually to get the original marks, we use variable as RebarPartlist.BarMark.
2. But, in case of user Marks we need to use RebarPartlist.UserMark.Mark
So RebarPartlist.UserMark.Mark will give you the User Marks instead of Original Marks.
Following image will show you the Variable/Field to achieve.
Result:
