| Product(s): | ProConcrete | ||
| Area: | Concrete Partlist | ||
| Subarea: | Sorting | ||
This wiki shows how to sort Concrete Partlist with position numbers of the objects.
1. Open your model and do the positioning.
2. Open the Create Concrete Partlist tool located at Data/Reporting > Reporting > Create Concrete Partlist.
3. In the Partlist Creation dialog, enter the required name for the MDB file and click on the OK button and then select Choose All.
4. Select the LST file in the Partlist Print dialog and click on the Edit partlist Definition button.
5. In the Properties under the Data section, change the Sort Order to Position Number and save the LST file.
6. In Partlist Print dialog, click on the Preview Partlist button.
7. Select your desire print option and click on the Start button.
8. Now, you can see the sorting order of the objects according to the position number in concrete partlist.
In this way, we can sort concrete partlist with position number.
